Makita Dolmar 6100 thoughts.
Wood Chopper
So so sleepy....
8:12 AM
Mechanicville NY
I hope lol. But for the time being I kind of like them long so they go over his shoes. The only cutting I let him do now is cookies.
Wait I thought you had it then sold it then have it? Now its sold again?
There’s a video somewhere
Simondo
12:12 PM
UK
Here is your start point (for those who like to know) .....brand spanker out of the box from Germany today, nothing added ,nothing taken away.
I don't think its a lump of a saw ...personally.
8:12 AM
Do you have any other 60cc saws to compare it to? For reference?
That's purty...
Simondo
12:12 PM
UK
That's purty...
Iv said this before.....All about "Subjective Perspective" Jeff .
One saw here is 22yrs older than the 6100 plus 2 are obsolete ......
Viewpoint on what the individual feels is big , small, tall .....Etc , plus the position the picture is composed from all have there part .:)
8:12 AM
Yes sir...nice trio...[emoji106][emoji481]
One could not go wrong with either of them.
Wood Chopper
So so sleepy....
8:12 AM
Mechanicville NY
8:12 AM
Yessir!!!
I could do another 6100...[emoji2957][emoji481]
Cerberus
Cerberus the aardvark, not the hell-hound!!
8:12 AM
Florida (tampa area)
Never. Here's a list of fixes that i recall:
Coil replaced under warranty, had been badly assembled, coil wire rubbed against the flywheel, causing grounding.
Carb diagphrams changed.
Throttle safety mechanism broke when i fell on it.
Muffler gutts broke loose last week.
Top cover replaced when it wore and rattled loosely.
Handle heater wiring repaired.
Chain catcher replaced many times, is quite week.
Engine still in prestine condition, i run alkylate fuel with cheapest full synt oil.
Can I ask why you source pure alkylate, but don't bother with a superior oil? Seems the good-petrol part of "great 2-cycle fuel" is the hard/expensive part, not using a proper/premium synthetic oil for increased-stick to the bar&chain!
Any elaboration is appreciated, after learning Re gas-station petrol (even the eth-free I'd been using) I switched to those pre-mixed cans (and add some synthetic oil to bring it from 50:1 to 40:1) and won't switch back after learning how big a deal it is! But I've already been racking my brain, "hmm is it worth finding a small air-strip and buying AV1000?" to save $$$$$ over those canned fuels, would be curious where you're sourcing non-oiled alkylate fuel if you don't mind :)
Ok time to go check your channel it seems to be getting a lotta thumbs-up here :D
7:12 AM
Find a place that sells 102 race gas.
Smells better
Cerberus
8:12 AM
I am with Simon on this a 421 is a nice saw to have around. And I have OCD also and as I’m no a pro cutter and want stuff to last forever all my kit gets air lined off after and a clean with a 2 Stoke mix doused cloth. Look new as.
hrrrmmm....why a rag w/ fuel instead of pressurized cans of carb-cleaner (for metals) and brake-cleaner(for plastics)? I use the Walmart $2 cans of these all the time on my saws, body gets brake-clean spray and bar/chain/sprocket-area get carb-cleaner (basically brake-cleaner w/ some oil)
The pressure in the cans lets me clean well w/o having to use a rag would definitely recommend it, w/ the walmart-priced $2 cans you can't go wrong!
(and re your alkylate, found the post where you mention your source, sadly never found something comparable here but I'm coastal there's **gotta** be someone selling pure alkylate around here if it's legal that is, even regular eth-free petrol is illegal to use in a car here, literally have it listed on the pumps sometimes although of course the proprietors don't care as long as you're paying!)
wcorey
8:12 AM
ma usa
Not sure how close it is to you but looks like Sebring regional airport has UL94, an unleaded alkylate fuel similar to 100LL.
Adamski
Plebus Splederns
12:12 PM
Essex, UK
Just seen this thread re visited, so I thought I would chime in with a Q. I would guess I've cut around 15 ton of wood with this 6100 now into approx 4ft lengths. Time to lean it out a touch as until you seriously bury it it's still running rich. What's the splined screw driver I'm looking for on this one. Not come across Makita/Dolly splines yet. Cheers
Sent from my Pixel 3a using Tapatalk
8:12 AM
You've gone all Hooskie on us. Why stop now? Lol
8:12 AM
Double D I believe. Usually I unscrew the screw on them and slot it with a dremel using a mini cutoff disc so I can use a screwdriver.
