- 5:48 PM
- Jan 14, 2016
- North western Ohio
I know most know how to make gaskets but some don't . If you get to dealing with old stuff sometimes you have no other choice because parts get very difficult to find .I found a several tutorials on the net . I use the mark and cut method using mix oil because it has blue dye which shows up better .---
This is a set ,actually two sets for the partner P-100's I'm working on .The excess on the outside will be trimmed of with a razor knife after the case is back together .The excess in the oil tank doesn't make any difference .
