Machining base without a lathe*
ABarrick
TacomaTRD98 on AS
1:59 AM
Newville, PA
It's brittle and little chunks can break loose. Especially if you didn't clean the surfaces properly.
I use a lot of hondabond 4 at work and I have never seen it become hard let alone brittle. Any idea what the brand of sealer was?
czar800
1:59 AM
Ellwood City
You'd think they wold have a pinch point label in the flywheel area...
Solve a lot of problems.
Great point!!
They will be hearing from my lawyer.....
:icon_writing: To whom it may concern,
I hurt my finger while modifying your saw to run like it should. If you and every other company didn't allow the EPA to bend you over this would have never happened...,
Termitebuffet
Home of the corn can muffler .....
1:59 AM
Midgetville Norf Kacolacky
Great point!!
Troof ...[emoji110]
Zoo City Sawz
Chainsaw Jim
Con Artist LLC
10:59 PM
Springfield Oregon
Loctite anaerobic type. On flat surfaces it'll be kinda temperamental if the surface isn't cleaned correctly then it'll eventually flake loose in the gapped areas. It isn't always a matter of proper cleaning if oil has seeped into the porous metals over years of use.
thesawincanada
For the love of saws
1:59 AM
Ontario, Canada
Pinched in flywheel two weeks ago checking sqwish. Swelling has mostly gone down. We all suffer from the same sickness when it comes to saws
