pbillyi69
- 2:28 PM
- Feb 21, 2019
- USA
if you look at one of your cutters from the front or the cutting edge are they thin like a knife or more like a chisel those are the angles i am referring to when i say inside anglesI'm familiar with cutter angles when grinding chain (although I don't have a grinder myself) are you referring to the inside top plate or side plate too? I hand file so I usually don't pay much attention or try to figure it out. I believe a 7/32" file produces somewhere around a 60° top angle on 3/8 chain, or are you referring to what I would call "down angle" when hand filing (I have no idea if that's the proper terminology) when I hold the file handle at a downward angle 0°-10° when filing?
