- 11:04 AM
- Sep 14, 2025
- moon
so, I had to remove and weld the valve cap on my old splitter the other day and managed to pop the spring loaded portion...oops.
At least I found all the ball bearings and spring
but, now I can't get it all back together. I believe that center ball needs to be below the smaller ones when the top ring is in place. There is a small spring just under the ball. I'm also not sure which way that top collar goes, note the groove on one end that the smaller balls rides. I have tried installing the cap and pulling up on the lever...no joy.
suggestions?
suggestions?
