Little bit of this and a little bit of that...
Red97
4:58 AM
MI
Been working on this for a while. Getting to the 40% stage figure I could share before I lose all my pics.
Echo cs 8000 with a 395 top end. 38mm stroke 56mm bore.
Stock echo rod on top. 70mm
Honda scooter rod on bottom 80mm
Red97
4:58 AM
MI
Cylinder on slight trimming to get the covers on.
Gonna have to get creative with an intake block/boot. Stock 395 boot is too long. Plan on running a wj carb.
This thing has some wild numbers for 94cc. Gonna try it as is then port in stages.
In, 94
Ex, 107
Tr, 120
Red97
4:58 AM
MI
Cylinder extension had to be turned down a bit in diameter to fit the echo case. The ex side bolt holes lined up perfect, intake side needed to be opened up a bit.
Both saws share a 13mm piston pin (cs8000/395xp)
Got the 395 jug to fit the echo case, try the 395 piston it is .220 squish.... Not good. Couldn't find a taller piston.
Thought the rod was shorter on the echo, not the case. Both rods are 70mm.
So I press apart the echo rod, of course it has odd bearing sizes. Only rod I could find was 10mm longer... luckily the 395 piston is about the tallest piston made lol. 066 BB piston skirt wasn't wide enough to cover the ports, so I try a 056 mag2. The dome just kissed the band. Hence the pop up.
Parts list so far
Echo case,covers,crank.
Husqvarna 395 cylinder, am 372 muffler
Stihl piston/pin bearing
Honda connecting rod
Poulan wj carb most likely
And a whole bunch of extra/scrapped pistons,cranks,rods
Red97
4:58 AM
MI
Badass build Joe!
*f-word yeah I've been waiting for this ! Thanks Joe!
Looking good joe
Bless yer Heart...this one is not for the weak willed.
stay the course for the destination may warrant the journey.
Thanks guys. Been working /thinking bout this build for a while. Definitely be worth it to heAR it fire up. Or not lol
I love seeing this Echo modding! Joe have you seen @chy_farm piped Echo twin?
No I haven't. Sounds cool tho.
Red97
4:58 AM
MI
Well it is a good dust collector... Stalled out a bit. Intake side is going to be very tricky to fit in that little carb box.
Echo 8000 use a hda carb, borderline enough carb for 80cc let alone 94. Wj kind of fits the carb box.
Then I got a bit side tracked with the 730 hybrid, that basically fell together compared to this.
I'll give it another go eventually. May end up a naked cant saw, but it will make noise one way or another. Until then it's got a cozy spot on the shelf.
