Philbert
Chainsaw Enthusiast
- 1:05 AM
- Jan 30, 2016
- East Dakota
Usually, they say that the heat will shrink the protective fibers.
Philbert
Philbert
Mine are definitely a fire hazard.I’ve always used Dawn and a scrub brush… Cutting trees that are on fire wearing hydrocarbon and sawdust covered chaps is no bueno. The FR part of the chaps may not catch fire, but the oil in them will. So I keep mine fairly clean and I definitely make sure I don’t get mixed gas on them.
We have an extractor at the fire station, that I have never thought about using. Until this thread. It will probably do a better job of getting them clean, too.
Thank you, Philbert.
Good thing I don't cut trees on fire!
Good friend of mine did concrete work, one of the guys was cutting rebar with a cutoff saw and the fuel cap fell off(stihl), the guy ended up getting a ride in a ambulance. Not cool getting lit on fire.
You all wear chaps? I must just be young and stupid.
Ouch! The Midwest heat and humidity during most of the time I'm cutting makes them unbearable. I always have a cell phone on me and first aid kit in the car and I'm always super aware of how I'm handling the saw. Maybe I need to think about it a little harder though.There are many shows that require them. If you do not want to were chaps then you cannot run a saw. I used to take a tote of extra pairs for guys to wear that did not have any. One of the fastest ways to bleed out is cutting the femoral artery.
This is a picture from years ago at a show in Iowa. The damage to the chaps was not even caused by chain contact. The recoil/fan shroud came off as I was making my upcut. I was very lucky as all I had was a helluva sore knee. I will say the three hour drive home was a bit rough.
Guys who make similar comments, and cut all day, often choose chainsaw, protective pants instead. Such as the Clogger ‘Zeros’.Ouch! The Midwest heat and humidity during most of the time I'm cutting makes them unbearable.
First aid kit in the car is a good start, can you get to it before bleeding out? femoral artery is about 60sec before losing consciousness and 3minutes to bleed out going from memoryOuch! The Midwest heat and humidity during most of the time I'm cutting makes them unbearable. I always have a cell phone on me and first aid kit in the car and I'm always super aware of how I'm handling the saw. Maybe I need to think about it a little harder though.
I should have just waited for your postIf you nick your femoral artery you probably won’t make it back to your car, much less have time you get yourself fixed before you lose consciousness and bleed to death.
I live sorta in the midwest (top of the mid-south/bottom of the midwest depending on who you talk to, and work in states that I would say belong to both), and I wear a pair of Labonvilles when I cut. Partly because the rules say I have to, and partly because I don’t want to die in a rural part of the state. I think the key to chaps in weather like where we live is to wear the apron style and not the wrap around style.
I also carry a CAT or RAT tourniquet on my falling gear in case of a freak thing with my chaps.
Yeah I should probably look into those clogger pants. I wonder how much time a belt cinched down as tight as possible would buy you?First aid kit in the car is a good start, can you get to it before bleeding out? femoral artery is about 60sec before losing consciousness and 3minutes to bleed out going from memory, belt worn emergency first aid kits are available.
911 15 years or so since I made a medical run used to be 5-10minutes avg response time depending on city longer if rural.
Best thing I found to beat the Midwest heat is expensive lightweight chaps/pants, I believe the last I heard is the average chainsaw cut is right around 100 stitches and 2-4weeks initial recovery if infection is not involved. $2500-5000 copay plus lost time from work are even $500 pants really that expensive? YMMV
Just out of curiosity. I don't plan on needing to find out.I wonder how much time a belt cinched down as tight as possible would buy you?
Depends on the belt and if you had the forethought on how to utilize it if need be instead of waiting to figure it out when needed.Yeah I should probably look into those clogger pants. I wonder how much time a belt cinched down as tight as possible would buy you?
Just to be clear, most chaps and pants do not protect the femoral artery (near your crotch).If you nick your femoral artery you probably won’t make it back to your car, much less have time you get yourself fixed before you lose consciousness and bleed to death.
Out of curiosity, have you ever had to dial 911? I hope the answer is no but if it is yes what was it for?Ouch! The Midwest heat and humidity during most of the time I'm cutting makes them unbearable. I always have a cell phone on me and first aid kit in the car and I'm always super aware of how I'm handling the saw. Maybe I need to think about it a little harder though.
Twice. Once because the neighbor lit his yard on fire and it was getting out of control fast and the second time was because someone in Saint Louis was going all over the place on the interstate. We also had the fire department out 3 years ago when we woke up to stuff in the machine shed exploding because it was on fire, there were 6 different departments out for that. Then just recently the big propane tank was leaking pretty bad last Saturday evening and the gas company wasn't answering so we called the fire department and they came out and then dispatch was finally able to get ahold of somebody. For the barn and propane tank I wasn't the one calling though.Out of curiosity, have you ever had to dial 911? I hope the answer is no but if it is yes what was it for?
