Kawasaki FS481V Motor
S Sidwell
1:43 PM
Georgia
When it dies, check for spark real quick while it's hot. Got spark, check to see it pump is pumping gas by pulling the line that feeds the carb and see if fuel pumps out while spinning over, works off crank case impulse. Can also pull the impulse line off and work it with your mouth. Needs pressure and vacuum to cycle the pump.
Steve, Samsung On5 using Tapatalk
S Sidwell
1:43 PM
Georgia
If no spark, might be the ignitor going out. Had this happened before, when the ignitor cooled off, i had spark.
paragonbuilder
1:43 PM
Norwich, CT
Good. You need to see if you are losing spark when it dies. Pull the air filter. Start it up. When it starts to die hit the intake with some starting fluid. If it picks back up and you can keep it going it’s a fuel issue. If it makes no difference it’s a spark issue.
Or at least a very good chance....
1:43 PM
OK. Will do.
This mower ran fine since I had it. Starts on first pull. Ran strong. Ran strong 2 weeks ago. I cut my lawn twice. No issues at all whatsoever. Until now. I started the mower made one pass, then the motor sputtered and died.
1:43 PM
I am really hoping it is just the vacuum fuel pump thingy. Easy to replace. Not sure what the life expectancy is of one of those are. I gots lots to do I guess. Lol
paragonbuilder
1:43 PM
Norwich, CT
I hate to see anyone throw parts at a machine. Best if you can diagnose it. Easy way to tell if it’s the pump is feed it with a gravity reservoir.
1:43 PM
I gotta take some time next week and open it up. I will check the pump. Pull the fuel line from the carb and put the line in a bottle and pull the engine over see if it pumps fuel. I gotta check for spark. If no spark it may be a coil.
WTF. Never ends. Lol
1:43 PM
I babied this machine too since I bought it new. Looks like it just rolled off the floor. Use only the best oil. Keep everything greased. Blades always sharp. Change oil, oil filter, fuel filter, plugs and air filter every year. All Kawasaki OEM. Not much I could do any better for preventative maintenance. [emoji17]
paragonbuilder
1:43 PM
Norwich, CT
Sometimes things just fail. It’s not you Jeff. But no spark may also be one of many safeties... don’t jump to conclusions and throw money away...
1:43 PM
OK Thanks for all this help.
tickbitintn
12:43 PM
middle tn
It sure sounds like a fuel issue...
Probably something simple...
One of these suggestions is probably it...
She'll live again. [emoji846]
S Sidwell
1:43 PM
Georgia
The ignitor is easy to check for getting hot and dying, spray cold water on it to cool it off, if you have no spark. When mine done it the third time, I hosed down the ignitor and cooled it off and got spark again til it got hot. $80 from John Deere, I liked to had a stroke.
S Sidwell
1:43 PM
Georgia
Don't use starting fluid, carb cleaner is safer, don't want to blow a cylinder head off with starting fluid, ether has a kick.
1:43 PM
LOL. Is the ignitor the coil?
S Sidwell
1:43 PM
Georgia
Little square silver box mounted on the outside of engine, two or three wires going to it. About "1 1/2 square and maybe 1/2 thick. Honda also uses them, made a little different.
S Sidwell
1:43 PM
Georgia
As was said, cheaper to check and test than throw parts at it. If it's a safety switch, disconnect the kill wires minus the shut off switch, may have to make a bypass wires so the system still has a loop to carry voltage, can get technical.
S Sidwell
1:43 PM
Georgia
Not that hard, check the simple stuff first then work to the hardest stuff last.
Wood Chopper
So so sleepy....
1:43 PM
Mechanicville NY
Jeff I just had this happen to my pos Kohler. Sounded like electrical. So I was just like you thinking it’s this or that or a coil or something. I took the carb off drained it blew it out put it back on and puured like a kitty. Water must have been blocking a passage way just enough where it ran really rough.
