S Sidwell
- 8:52 AM
- Oct 9, 2016
- Georgia
When it dies, check for spark real quick while it's hot. Got spark, check to see it pump is pumping gas by pulling the line that feeds the carb and see if fuel pumps out while spinning over, works off crank case impulse. Can also pull the impulse line off and work it with your mouth. Needs pressure and vacuum to cycle the pump.
Steve, Samsung On5 using Tapatalk
