Just Bought a Small Engine Tachometer
GBertolet
3:16 PM
PA
I just bought a Fast Tach tachometer. It has a replacable battery, and it works on induction, with no wires needed. I had a Treyset, and the scale came loose, and now spins around, making any readings impossible. The Treyset was difficult for one person to use, while holding the throttle open of a chainsaw. I saw an ad for this tachometer, and bought it. It covers 2 stroke, 4 stroke, and multi cylinders. What a pleasure to use. It can store the max rpm of your test engine. Hold it a foot from your plug wire, and you are good.
I had a brain fart, by setting the option for every other revolution for a 4 stroke small engine, finally realizing that the plug fires on both compression and exhaust strokes. At least I learned that I don't have to change anything for 2 or 4 stroke, single cylinder engines. I paid $85 for it. Not cheap, but it is of better quality than much of the low cost ebay stuff.
https://www.tinytach.com/chainsaw-tools
2:16 PM
They be handy and a dude here sells and 3d printer holder and allows you to snap it on you handle so you can watch it through the cut.
jakethesnake
I Am The Snake
3:16 PM
Here & Now
Yes. I have the holder too. I recommend it
GBertolet
3:16 PM
PA
Who makes the 3D holder?
JB-PlantHeirloom
3:16 PM
Georgia
Now that I might be upgrading my game, building stuff, I might go for another tach. The wrap the cheap wire around the spark plug wire is a hassle and gets old. Plus, almost impossible to do while actually cutting with the equipment.
