Calling Out The Internet BS
IffykidMn
3:37 PM
Minnesota
Yep, it's just surface coloration. Even color case hardening on firearms, which is a much more involved process that penetrates somewhat deeper, is pretty fragile (as far as retaining the desirable color, anyway).
Interesting👍 I always thought of color case hardening as decorative in nature as relatively low heat surface and not structural annealing temperatures.:thinking:
heimannm
3:37 PM
Dike, Iowa
The temper colors (yellow, straw, brown, purple, blue) are oxidation and as such polish off very easily as Philbert has pointed out already.
Below 390° F no discoloration, over 575° F and you start to get irradiance where the material is glowing. Oxidation colors will appear when the material cools again.
Bluing of steel as in gun finishes is a different process.
Gun bluing is a chemical conversion process that transforms red iron oxide (rust) into black iron oxide (magnetite) to create a protective, corrosion-resistant finish on steel, improving both durability and appearance. It creates a thin, blue-black layer without changing metal dimensions, typically through hot, cold, or rust-bluing methods.
Mark
Woodtroll
4:37 PM
Mtns of SW VA
The coloring is certainly attractive, and now is done mainly as decoration, but casehardening was originally used to harden the outer layer of ferrous metal by driving more carbon into it under high heat while leaving a softer inner core, desirable for "toughness" in tools, guns, etc. made back before tool steels and such were developed. The item is packed in a container with charcoal and bone (in the case of firearms), the whole thing is heated to something like 1300 degrees, then quickly quenched, usually in oil. True color-casehardening is a pretty involved process. Here's a couple of links if you care to know more. Turnbull is considered an artist for his color case-hardening and gun restoration skills:
As @heimannm pointed out, gun bluing or browning is a completely different process, whose purpose is to provide a protective layer on the steel. A good bluing job is certainly attractive, but the appearance was not the primary purpose originally.
Probably more than you wanted to know (sorry), but well-made tools like guns and chainsaws have always fascinated me, and some of my interest lies in all the many side details.
Philbert
Chainsaw Enthusiast
3:37 PM
East Dakota
You have a specific, bar polishing tool, as I recall?
Philbert
Philbert
Chainsaw Enthusiast
3:37 PM
East Dakota
Surface preparation tool from Harbor Freight.
Thanks.
I’m not promoting or disparaging HF: I just recall that from an earlier post (somewhere), and it seemed to fit the discussion.
Here are a few more images:
Note that other companies also make these kinds of tools, and there appear to be a range of abrasive wheels, including wire, ScotchBrite type, flaps, etc.
Looks like a good tool if there are a lot of bars to do. I suggested a belt sander as another option.
If someone just wants to ‘cleanup’ a bar, and was flexible about the resulting ‘scratch pattern’, a random orbital sander would work too.
Philbert
IffykidMn
3:37 PM
Minnesota
Thank you for providing links.
I have seen some of the Turnbull work having interest in both SASS and NCOWS and done a few small pieces such as trigger guards and locksets, also have minor knowledge in the browning process putting together several BP rifle kits with a fleeting stint in the Rendezvous scene but mainly BP roundball hunting from 36cal small game up to 54cal big game.
heimannm
3:37 PM
Dike, Iowa
I believe that HF has moved from the Bauer line to the Hercules, the last drum(s) I picked up were Hercules and they seem to work O.K.
Mark
Vintage Engine Repairs
4:37 AM
australia
Thank You! :thumbsup:
Color me blue guess I envisioned the coloring penetrating deeper as the line is further back from the bar rail itself.
It’s just oxidation - affects the very surface. That’s why TIG welding can take steel to a molten state and if you keep the shielding gas over the weld, you won’t get any discolouration.
heimannm
3:37 PM
Dike, Iowa
I think you are baiting me Thomas...I've only used it on chainsaw bars...videos show guys stripping auto body panels. I guess you are supposed to call it a surface conditioning tool...
Mark
