I set the H & L screws accordingly & turned up the idle screw & had no better results.I pulled the impulse line off the carb,pulled the spark plug out,& pulled it over with my thumb over the impulse line & felt no suction.I noticed the saw ran a bit better with the choke partially on.It has a "miss" in it at WOT.It has a new Boscsh WS7F plug in it.I'll pull the carb & go through it & put new diaphragms in it & see if that m,akes a difference.The saw refuses to idle whatsoever.I've never had the carb off the saw in the 7 yrs.I've owned it.BTW,how do I replace the impulse line,it may have a hairline crack from sheer age.
