Jonsered 670 champ intake leak
davidwyby
Tree felling enthusiast, 288 collector
8:26 AM
Extreme Southeast CA
Why it’s leaking isn’t obvious to me, but this is the first one I’ve messed with. @afleetcommand @Spike60 seems like I saw in one of your videos these boots are NLA? Time for @huskihl 272 top end? :D
11:26 AM
Not saying it’s not leaking, but of all the red and orange saws on this case, this intake block is the least troublesome.
Make sure it’s not worn through on the bottom and make sure there’s a wire or clamp on the cylinder side
Ronie
11:26 AM
NC
It looked to me like the spray got sucked in from behind the boot on the cylinder side.
11:26 AM
Brass inserts might be pulled a little bit. Could remove the rubber and file them a little shorter so the carb tightens better to the boot. If that’s it
11:26 AM
Those blocks do pop up on eBay. I picked one up new a few years ago for $20 or so
Johnmn
10:26 AM
Minnesota
I bet have have some 670 intakes on hand. I can check if needed
11:26 AM
davidwyby
8:26 AM
I tried spraying just back there, no stall.
I'm with the missing clamp camp.
Heard somewhere there was a new boot being made, maybe it was @Czed ?
It has the heavy duty flat steel clamp with screw closure.
@davidwyby the 670 wasn't called the champ for nothing. Be a shame to replace it with something else.
I ran Kevin’s ported champ at the gtg. I’m sure a kevined 272 would whomp on a 670. But I would not want to give up the jred high idle for the husky high idle.
I bet @huskihl is right and the brass is pulled or the rubber is shrunk or both.
I will investigate further.
I do have a boot coming from chainsawr. Should have ‘vestigated more first maybe.
davidwyby
8:26 AM
Well…this thread got some life going in here…*thumbsup*
