Jonsered 525
Rich Fife
Sally slap my ass
10:44 AM
Central New York
A parts designer at work found out that I work on saws... he asked if I could get his Jonsered 525 running. He purchased it new in the 80's for a little over $200. He said it hasn't ran in 2yrs. It would fire up, but once warm, it would cut out.
Rich Fife
Sally slap my ass
10:44 AM
Central New York
He gave me a copy of the parts pages. I wrote down the stock numbers... and made a list of parts.
Rich Fife
Sally slap my ass
10:44 AM
Central New York
The piston and cylinder have seen better days.
Rich Fife
Sally slap my ass
10:44 AM
Central New York
I cleaned the cylinder as best as I could. I couldn't find a suitable drop-in piston... luckily enough, I had a Dolmar 111 piston on the shelf... the intake skirt was a little shorter than the OEM piston and it didn't have windows. The biggest 'issues' on the dolmar piston... the compression height and the gap for the small end of the rod. I machined a pop-up, trimmed the sides of the piston and I had to machine some spacers along with heat treating them.
Rich Fife
Sally slap my ass
10:44 AM
Central New York
I ended up replacing the base gasket, the coil, the piston and the fuel lines. I also opened up the exhaust under the deflector. Given the condition of the cylinder as well as no port work or porting, this saw runs pretty darn good for a 49cc saw. By swapping the the piston we gained intake duration as well ad exhaust duration... without the windows I feel as if the charge is a bit more... onviously, the pop-up also helped with the gains.
HuntFishMB
OPE Member
9:44 AM
Winnipeg MB Canada
Thanks for your great detail!
How did you hone the cylinder head with those deep transfers?
Im realizing a stone hone will catch on the transfers.. will a flex hone work?
HuntFishMB
OPE Member
9:44 AM
Winnipeg MB Canada
Do you have another link to your video!
David Young
Safety First !!!!!!
10:44 AM
vt
nice save. you probably could have cut a lot of that missing plating out and set the intake to a reasonable number. I have one of that style saws that is a parts saw. If I remember right it had similar wear on the intake side must have been a bad filter set up on those.
Rich Fife
Sally slap my ass
10:44 AM
Central New York
I used a Flex hone. It didn't do the flex hone any justice. User beware should be applied. Lmao
