BonScott46
- 4:26 PM
- Jul 20, 2016
- Sweden
I believe it’s a direct swap. Although I fail to see why the loss of finish on the connecting rod warrants a crank change. What am I missing?Pulled down my low hour 2071 and found this.
View attachment 228593 View attachment 228594
Does the later model 372 crank swap in or do I need to change the PTO side case half as well?
Is it supposed to narrow like that? It starts narrowing where the finish is missing. I have never seen a crank like that but i have not seen a lot of cranks either.I believe it’s a direct swap. Although I fail to see why the loss of finish on the connecting rod warrants a crank change. What am I missing?
Yes sirIs it supposed to narrow like that?
Well that is good news. There was quite a bit of carbon/sooty build up in the cases, on the piston and in the combustion chamber. When I bought this saw the piston was very clean and I have only run max ten tanks of very clean burning fuel through it. Should i give it a polish and let it ride then?Yes sir
I would, nothing wrong with that con rod at all. I just had my 372 apart not long ago but don’t have any pics of the con rod. I know it looked exactly like yoursWell that is good news. There was quite a bit of carbon/sooty build up in the cases, on the piston and in the combustion chamber. When I bought this saw the piston was very clean and I have only run max ten tanks of very clean burning fuel through it. Should i give it a polish and let it ride then?
Great, thanks for the help!I would, nothing wrong with that con rod at all.
No problem...happy cuttingGreat, thanks for the help!
Oh really...What's the gain with using a 268 piston?? Lighter?? Never seen that trick before
More compression, more intake timing, lighter piston and you can use a stock gasket.Oh really...What's the gain with using a 268 piston?? Lighter?? Never seen that trick before
Nice. Thanks for sharingMore compression, more intake timing, lighter piston and you can use a stock gasket.
