JonCutter thread...
Spike60
2:05 PM
Ulster County, NY
How are those 62cc X-Bull's?
I just CAN'T get an orange Joncutter. I've got a 100 orange saws as it is. :)
Simondo
7:05 PM
UK
If, the Joncutter saws have there roots in the Zenoah brand then this may be of interest.
There are 2 saws that the Joncutter G4500 " May" be based on ....
One has more power than the other in stock form.
Leafy
2:05 PM
NH
They're pre-strato. They exist as such good copies because zenoah licensed the construction of the whole saw into China just before the switch to strato for the American market.
NSEric
3:05 PM
Nova scotia
CR888
4:05 AM
I bought a 62cc x-bull and I measured it when it arrived and it was a 52cc and they refunded me.
I here quite a few China saws are like that, they often lie about the real displacement. Honesty, ethics & moral fibre are tossed far when it comes to putting cheap China product in the hands of consumer. I dare say 90%+ would never know their saw was 10cc less than it should be. The typical Jon cutter cutty-cutty fast saw purchaser would struggle to remove the air shroud.
kgj1119
OPE Member
2:05 PM
Plainfield Illinois
I’m thinking about getting the 5800. What bar and chain fit these
2:05 PM
Leafy
2:05 PM
NH
K095 mount. But the factory.325 20" bar is more like 19" so it uses a weird dl count chain, there's a guy on ebay that seems to be making lgx chain off a roll if you search by the drive link count. But if you put a normal length bar on it it'll use a normal dl count. You're probably getting a spur clutch on it so if you want to switch to 3/8 you'll need a new clutch.
kgj1119
OPE Member
2:05 PM
Plainfield Illinois
I thought the 5800 came with a 3/8 not .325?? I may be wrong though
NSEric
3:05 PM
Nova scotia
It does.
It also has a rim sprocket so you can switch easily.
Huztl specs a 20 inch 3/8 bar and chain for the 5800. I think its much better with a 16 inch .325 like most 50cc saws are.
I put a stihl ms250 3/8lp bar on mine with the stock 3/8 rim sprocket for a bit. This set up is probley the fastest but I like .325 better so I switched to that.
You could buy the bar/chain for the joncutter 3800 from huztl and put it on the 5800 if you want 3/8lp or the bar/chain/rim sprocket for the 4500 if you want .325.
They're all K095 or small husky mount like a 450, 51, 350, etc.
