redline4
I'm huge in Japan
- 9:31 AM
- Mar 12, 2018
- Rosholt Wisconsin
@redline4 I have a used AM clutch, which is good as a new OEM, I could sell you for, lets say, oh, around $50.00...
Nice saw. And these detailed threads are great BTW.If one delves deep into internet 2 stroke garden tool lore one will hear of the Stihl 044.
According to ancient scrolls it houses mythical tree killing capabilites and human healing powers.
I've never even pulled a start rope on one much less made a cut, but figured it's finally time.
Bear in mind I'm not a trained professional in any aspect and I fully expect Dallas to tell me I'm a slacker multiple times before this is over.
Available time, money and parts availability will dictate the speed of this build.
I have no set direction other than get it going without breaking the bank.
If it's a good part, it will get re-used.
If it's repairable, it will get repaired.
So here we go.
Starting out with a grungy, west coast 044.
View attachment 368325View attachment 368326
The wrap appears bent and the tank is definitely tweaked. We'll get a better look at that later
A quick spray down with degreaser and hit it with the garden hose.
Absolutely fixable. I've used stiff wire for reinforcement, and JB Weld.I don't know if I'll be able to do anything about this tank, but I'm going to try to salvage it...
View attachment 368398View attachment 368399
Remove the coil
Remove the intake
Easy clean up there.And some jug pics.
View attachment 368407View attachment 368408View attachment 368409View attachment 368410
I'll get a better look at it tomorrow
That's all for tonight.
Great thread my friend! I love the combination of comedy and seriousness of each detailed step.....kinda feels like my wife talking me through dealing with my 18yr old daughter.....lmfao.....
I just went through nearly this exact process with my 10mm 044 build. It was way rougher than yours but came out amazing.
On a serious note, can anyone out there confirm or debunk what I've believed to be the case for several years now regarding the difference in bottom end volume between the 10mm and 12mm crankcases? It seems to me that the case volume most certainly is different, but I've never actually did a liquid volume measurement of these cases. I'd love to be able to do a test to either confirm or debunk my suspicions.
In my past several 044 builds, I've installed 12mm crank assys into 10mm cases. It's fairly simple, but you do have to groove a channel where the connecting rod makes its rotation during the crank stroke. Me, being of a long lineage of redneck background, I used a small round carbide burr and made a very alight groove that allows the rod to clear during the stroke. The groove is big enough that it won't interfere with the conn rod even considering expansion from heat.
The most recent one I've built has impressive power. The transfer lowers and throats were open up and swaged out, took the base down to .018 clearance at TDC, bumped the timing a few degrees north and DP'd the muff, it's probably one of my favorite dailies already!!
Yes sir, boss. It's most definitely smaller. What I'm getting at (I'm not always the greatest at wording my thoughts sometimes) is how significant is the difference in volume. Does that difference equate to a "supercharged" effect?You know that the 10mm case is smaller my friend. If not, you wouldn't need to grind out that groove to run a 12mm crank in it.
I can't say for sure....but I know that that best running 044s I've ever built are the ones with a 12mm crank in a 10mm case.Yes sir, boss. It's most definitely smaller. What I'm getting at (I'm not always the greatest at wording my thoughts sometimes) is how significant is the difference in volume. Does that difference equate to a "supercharged" effect?
I'd like to use stuffers in an 044.
Not that I'm aware of.Did Stihl ever use them in anything?
That sounds like the confirmation I've been looking for sir. You've got way more experience than me! Thanks for chatting Randy, hope yinz are all well down there on the farm.I can't say for sure....but I know that that best running 044s I've ever built are the ones with a 12mm crank in a 10mm case.
