- 1:53 AM
- Feb 23, 2023
- Montana
Looks like a heat gun, some epoxy and plastic would fix that up.
you need a new clutchPull the handle off
Remove the linkage from the band
Pull forward on the band and pop it out of the case
View attachment 368372View attachment 368374
I then took out the 2 muffler to jug fasteners.
Is there supposed to be a heat shield? I didn't look at the ipl yet..
What's the yarn about 10mm vs 12mm 044s slacker?
this isnt the one i sent in parts long ago
slacker
If you want to go full norwegian on that tank, these pic's should give you a few ideas.
View attachment 368413View attachment 368414View attachment 368415View attachment 368416
One trick is you can pop off the throttle linkage without taking the black handle off. Just pull the trigger to full throttle to expose the end and carefully remove from trigger and then from carburetor.
If you want, send me that cylinder and I will clean it up for you.![]()
If I had been a day ahead, I could have sent it with Ryan.
By the way, his Dad is looking for a saw, and I was pimping him on that 361 you've got..
He seemed interested.
I'll have my machine call your machine about jug cleaning..
You may have already found this info Adam.What's the yarn about 10mm vs 12mm 044s slacker?
