- 5:29 PM
- Dec 31, 2015
- East Jordan, MI
Lol yep.Even when Tim brings in his pitch and creosote-covered 455 Ranchers?
Worse one I ever did was a 7900 that canola oil had been used in instead of bar oil.
Believe my worst was a 372 that was running drain oil. Or maybe canola. Everything was black and gooey. Every screw head needed blown out with air. I was covered from head to toeWorse one I ever did was a 7900 that canola oil had been used in instead of bar oil.
Did you charge extra?
There was a mild cleaning feeDid you charge extra?
My MMWS 395 oiled a 50" bar just fine buried in very pitchy fir. Pitchy wood is an excellent test of oiling capability. It had the power to pull a lot more bar, but i didn't have a 60" to try the oil capacity out. I'm pretty sure the power was there for a 72" bar, no problem. Unbelievable for 93cc's.
I've thrown away a complete 365 part saw just because it use used DIESEL engine oil as bar oil. Everything is black. Just too messy. Blacken my table, clothing, tools. Pissed me off. I would spend more time cleaning everything after fixing that saw.Believe my worst was a 372 that was running drain oil. Or maybe canola. Everything was black and gooey. Every screw head needed blown out with air. I was covered from head to toe
I would dumpster dive for that MFER.I've thrown away a complete 365 part saw just because it use used DIESEL engine oil as bar oil. Everything is black. Just too messy. Blacken my table, clothing, tools. Pissed me off. I would spend more time cleaning everything after fixing that saw.
There’s this thing called brake clean or gas, a brush and a plastic tub. I heard they work well and are affordable. LolI've thrown away a complete 365 part saw just because it use used DIESEL engine oil as bar oil. Everything is black. Just too messy. Blacken my table, clothing, tools. Pissed me off. I would spend more time cleaning everything after fixing that saw.
I think paint stripper would work though.There’s this thing called brake clean or gas, a brush and a plastic tub. I heard they work well and are affordable. Lol
So I can send you some Mini Macs?Plenty of other low-life hacks around here to pick up the slack though
#UsedSawsMatter
Their would be some broken hearts with chowder parts.What yall think about a NOS discontinued saw build off?
Yep.....lots of guys here that can do as good or better on these saws than I can.
Canola oil would gum the works up alright, especially if the saw had gotten hot.
I rebuilt an 044 for an arborist in Florida once that had cut a lot of Palm trees. I guess Palm sap is real acidic - it had several holes eaten
through the bottom of the case. The bar pad was about half gone.
I’d like to see some antique saws running.
Preferably from manufactures that no longer exist.
No plastic, no chain breaks. Maybe a handle on the working end, so your friend can play too.
I actually think the foaming cleaner and the power washer would be about the best on one of these. I clean up almost every part of a dirty saw in the parts washer, but some of these are really badThere’s this thing called brake clean or gas, a brush and a plastic tub. I heard they work well and are affordable. Lol
Got any big ones? CP125? 655BP?
