- 4:12 AM
- Jan 1, 2016
- Warren Center, PA
Cool old saws they are.My Jonsered 930 super is amazing for a saw with no air injection. I guess some are good designs.
I think it's a good idea to clean your airfilter everyday or twice a day in the timber regardless of how dirty it is.
Not sure why you're having troubles with the 346. I have a 2152 that pre filters exceptionally well and 346 is the same system.Unless it's a 394/395. I have a low top 394 I bought new and may have cleaned the air filter once in like 60 or so tanks of fuel, and it was as clean or cleaner than a 346 after 2 tanks
Tell that to stihl!! Pnw rep for stihl, and my local dealer told me that if i removed the filter before it was visibily packed with debris that they will and can void all warranty. Something about the seal of the filter. This was on the 241 and 661I think it's a good idea to clean your airfilter everyday or twice a day in the timber regardless of how dirty it is.
I have no time for know it all stihl reps.... They drink too much koolaid.....Tell that to stihl!! Pnw rep for stihl, and my local dealer told me that if i removed the filter before it was visibily packed with debris that they will and can void all warranty. Something about the seal of the filter. This was on the 241 and 661
How would they know?Tell that to stihl!! Pnw rep for stihl, and my local dealer told me that if i removed the filter before it was visibily packed with debris that they will and can void all warranty. Something about the seal of the filter. This was on the 241 and 661
actually, I use 357/359 airfilterholder&filter on all my 346's, some of them are not ported.Also, if you port a 346xp you can take advantage of the intake boot/carb/filter from a 357xp/359 which is a larger filter less prone to clog up.
How so you get the choke lever to fit?actually, I use 357/359 airfilterholder&filter on all my 346's, some of them are not ported.
I was wondering the same thing. How would they have any idea how often one services the filter.How would they know?
They won't.I was wondering the same thing. How would they have any idea how often one services the filter.
Sent from my Z832 using Tapatalk
Having been part of Stihl (see my sig) I can tell you without a doubt that is absolute nonsense .
Air filter service is part of maintaining your saw , just look in the Ops manual .![]()
Hmmmis it this area you're thinking about? if so, I cut out a bit on each side so the airfilter box has some space to move, otherwise everything get squezzed
