- 7:36 PM
- Jan 1, 2016
- Warren Center, PA
And you do a very nice job.I cut base and squish for $50.
Btw are you still working out of town??
Stupid question, does the squish have to be cut if the base is cut? I would think if you could cut the base, and it not to be too thin when you achieve your squish, that it would be good enough.
So, no, you don't have to cut the squish. I am trying to understand why you would cut squish. Maybe squish is to tight with out gasket so cut squish to get 0.020?
I would like to see spec like that too. It would help to answer my questions. The only place I have learned is on the web here and at AS.
Sanding a little off a base for yourself may and could work just fine. Doing it for others is asking for trouble, especially if a lot is removed. Once you lead off a little it would be like a rumor, gets worse.
I tried sliding it , but didn't work so well for me. I just rocked it back in forth 10 times then turned it 90. Kept doing it til I got all the way around. Then checked my measurements . Repeat...I didn't spin the jug like t4 did though. I slid it the length of the belt, turned 90°, repeat.....for over an hour
You forgot about the other 2500 repeats....I tried sliding it , but didn't work so well for me. I just rocked it back in forth 10 times then turned it 90. Kept doing it til I got all the way around. Then checked my measurements . Repeat...
TruthYou forgot about the other 2500 repeats....
I've cut some bases that certainly wasn't flat from the factory.
If 003 or so is a problem then how you tourqe the cylinder would affect it.
No possible way that every case half and bearing pocket or cylinder could all be identical.
That's what I mean by bearing bores,I've just changed one case and sometimes it's not even close to the other one.They have geometrical tolerances to follow set by the engineers.
.003 can be huge in my world. Flat and perpendicular are two totally different things.
