Gentleman
- 7:52 PM
- Nov 30, 2015
- Daytona Beach, Florida
Can I get some opinions on this cylinder/piston kit warranty sheet I'm working on. I want to include it with every cylinder kit that we sell. Will it cut down on the complaints from guys who put new cylinders on without fixing the problem that caused the failure. My fried Lee Smith from Lil Red Barn told me that it is working of him.
Any thing I should add or change? I'm sure I will get some good comments.
To ensure that your machine starts and stays running for a long time you must perform the following tests before installing your new part.
In any 2-cycle engine you have two compression tests to perform, primary and secondary. Most people only do the secondary compression test. The secondary compression test is done by screwing a compression tester into the spark plug hole and pulling the starter rope. This test will only tell you the condition of the upper cylinder.
The primary compression tests are in the lower end of the crankcase. This test consists of vacuum and pressure tests. All 2-cycle engines must be air tight to perform correctly in operation. There cannot be any air leaks of vacuum leaks. Failure to perform the vacuum and pressure tests will void your warranty.
This testing information is true for all 2-cycle engines. Before any new parts are installed, whether OEM or aftermarket, these checks must be performed or there is a good possibility the engine will fail again. Do not just replace a cylinder or piston kit because it failed. It failed for a reason. If you don’t solve the problem it will happen again.
Possibilities the engine could have failed:
· Carburetor was improperly adjusted
· Improper fuel mixture
· Mechanical failure
· Loose cylinder bolts
· Leaking gaskets
· Impulse line
· Leaking intake manifold
· Carburetor inlet screen has debris causing fuel starvation
· Dirt ingestion
· Leaking oil seals
· Ethanol-based gas sat too long
In addition to the compression tests, you should also check your crankcase pulse. Primary compression is one part of crankcase pulse; the other part is cylinder, piston and ring condition. Crankcase pulse is necessary for the fuel pump, which is built into the carburetor, to pump fuel from the tank for the engine to run. To check the crankcase pulse, remove the carburetor and spark plug, apply some oil inside the impulse line and pull the starter handle. Oil should pulsate inside the hole. If you don’t have good crankcase pulse the carburetor will not perform correctly to keep the engine running at peak performance.
Cylinder/Piston Kit Warranty Information
· Leaking gaskets
· Impulse line
· Dirt ingestion
· Leaking oil seals
We recommend having a qualified technician perform these tests and install your parts.
Our cylinder kits are covered by 30-day warranty.
Failure to perform these checks will void your warranty
