I bought a Chinese diesel
LAWN BOY
Pothole
9:48 AM
Merrill, WI
IMG_9598.jpegI got one of them cheap diesels from China, 3hp. I haven’t gotten it to start yet. Tank is almost full with premium diesel. Idk why not much is in the fuel filter. I primed it and it pumped out a little as tho I properly primed it. Then it just won’t start. I think I have the throttle on but it doesn’t seem to work right. Any ideas? I’m not finding the EXACT specific procedure for first start. I’m trying to start it at half throttle. Do I need to hold decomp down all throughout pulling to start or how does that work? I used shell Rotella 15w40 oil.
  • Like
Reactions: Lnk
ammoaddict
12:48 PM
Granite Falls, NC
I've never seen a diesel that small. What is the benefit of it over a gas engine?
  • Like
Reactions: Lnk
farminkarman
I like the red & black ones
11:48 AM
Neenah Wisconsin
View attachment 431160I got one of them cheap diesels from China, 3hp. I haven’t gotten it to start yet. Tank is almost full with premium diesel. Idk why not much is in the fuel filter. I primed it and it pumped out a little as tho I properly primed it. Then it just won’t start. I think I have the throttle on but it doesn’t seem to work right. Any ideas? I’m not finding the EXACT specific procedure for first start. I’m trying to start it at half throttle. Do I need to hold decomp down all throughout pulling to start or how does that work? I used shell Rotella 15w40 oil.
Try cracking the line at the injector and crank on it (or in your case pull). When you quit seeing bubbles, tighten the line back up.
LAWN BOY
Pothole
9:48 AM
Merrill, WI
Not much benefit other than cool factor
fuel line is not see through, so where would I see bubbles?
LAWN BOY
Pothole
9:48 AM
Merrill, WI
After lots of trying it started a couple times but only for like 2 seconds each. Then after much more trying it started and ran, but smoked white out of air filter box so I shut it off after 9 seconds…………..
  • Like
Reactions: Lnk
Woodpecker
Sassy Madam
12:48 PM
With most all diesels air in the fuel like will vapor lock them. You need to get the fuel to the injector without air. You’re having trouble because there is air in the line.
Bill G
11:48 AM
Keep it around to have fun running sometimes, maybe put it on a gokart or mini bike frame someday. Maybe make a custom exhaust for it.
Sounds like a lot of money for a kid to spend on something he may use some day but I guess when I was a kid I bought a lot of guns that I did not need. The same with tractors.
