Jake Dykstra
- 7:37 AM
- Nov 25, 2018
- NW Washington
Should be 12mm on both is my understanding.I see the stroke is the same, are the pin's the same diameter?
It will be faster for sure. Hopefully by guys like upstate doi g these builds the big 3 will start looking at lightweight big cc options in the futureI'd love to try that out on some trees.
autotune could be interestingI thought 86?
I think I want one. But autotune.
the transfers of the 592 / 585 cylinders are front fed, the 372 case is pretty thin there so I'm curious how you plan to get around that. I wonder if you might be able to use a 576 bottom end (the front bolts would need to be redone, but maybe it would be work?)Thats exactly whats on my bench next. 592 should be here next week!
I was thinking of starting with a 585 if I can't get enough weight off the 592 piston.
If the the CNC logistics work out, might have an a way to make these more repeatable. Would be neat to be able to get some in hands of people who would use them more than I can to see where failure points are.I'd love to try that out on some trees.
I assume once new 564 runs through the bugs it may have, it could be the upsized on the CC range. I'm sure they've got the beancounters working on the numbers for itIt will be faster for sure. Hopefully by guys like upstate doi g these builds the big 3 will start looking at lightweight big cc options in the future
Not planning on using the 372 platform for the 592 build. Going to use the 572 platform.the transfers of the 592 / 585 cylinders are front fed, the 372 case is pretty thin there so I'm curious how you plan to get around that. I wonder if you might be able to use a 576 bottom end (the front bolts would need to be redone, but maybe it would be work?)
I assume once new 564 runs through the bugs it may have, it could be the upsized on the CC range. I'm sure they've got the beancounters working on the numbers for it![]()
What is the stroke? 500i is short stroke. Interesting.Not planning on using the 372 platform for the 592 build. Going to use the 572 platform.
The 564 looks interesting for what it is but it has a short stroke so not much chance of growing up to be a big boy.
Why are the new saws going short stroke? That makes sense on a 4 stroke (more room for valves) but a long stroke on a 2 stroke engine allows for more port area per degree of rotation. Is it a weight reduction thing? You can build the rotating parts lighter with a short stroke engine and there will be less strength required in the crankcase.What is the stroke? 500i is short stroke. Interesting.
| Pull 1 | Pull 2 | Pull 3 | Pull 4 | Pull 5 | Pull 6 | Best 3 Average | |
| Horse power | 7.95 | 7.68 | 7.84 | 7.86 | 7.88 | 7.84 | 7.90 HP |
| Torque | 5.37 | 5.29 | 5.32 | 5.30 | 5.32 | 5.32 | 5.34 TQ |
1pc cylinder
Any bore, stroke, cylinder, any cc
No power adders, nitrous, blower,turbo
Gasoline 40:1 dominator, 90 octane e free
365/371/372/jonsered/clone case
Top cover/plastic etc
Working chain brake
Working choke
Muffler/pipe can be no longer than 6" past the original muffler area
Saw must start/idle/run
60 second warm up
- 5, 10-12 second pulls
- Average your best 3 pulls
Very interesting! Looks like the winner was a 38mm stroke. Over 11 horses in a 372!
Edit: Not sure how anyone squeezed a 38mm crank in a 372, but 38mm stroke x 55mm bore = 90.28cc.
