upstateamish
- 3:52 PM
- Jul 13, 2021
- upstate new york
No problem, glad to be able to contribute something worth reading!Good stuff man. This is a part of the reason why I joined this forum.
The other part, people aren't truly open about sharing the nitty gritty details of their port work... with that said, at least there are threads like yours that continue to peak my interests. Thank you.
Gotcha on those turning tools, the one I have is BXA I believe but I'll double check to confirm. Might be worth catching up to mill them but I may look at what an AXA quick change tool post runs and make that order. (would be a shame to mill them if that's the easier solution)Side note: if those turning tools are too thick, I can toss them in the mill and machine them to a specific thickness.
Those were for an AXA wedge style tool post
I've been wondering what can be done with those cheap 58cc Chinese saws.No problem, glad to be able to contribute something worth reading!
I get why some people that sell port work want to keep specific things that work for them a bit secret (as it could cut into their margins or get leveraged by other porters.)
In my world, not everyone in my social circle is that into chainsaws (I know quite a shocker) but even those who are into chainsaws aren't into building the hybrid weird one off builds. Why hoard the info on the build process when I can share it?
I like working through challenges and solving puzzles and this is a great place to show off what I'm learning (and failing at) and who knows, may even help others who are dum...errr ambitious enough to do something similar.
The prototype 2 crank swap is interesting to me, once I get the air leak fixed on this one and dialed in a bit more. I'm excited to start another build another based on what I've learned.
I appreciate everyone that has read through the thread so far and provided insight and/or offered actionable feedback!
YesssssssI've been wondering what can be done with those cheap 58cc Chinese saws.
No worries. The 390 piston has a larger wrist pin diameter which won't fit the 372 crank. The 661 is a 56mm piston with the right wrist pin diameter for the 372 crank and then can be turned down to 55 mm to fit the 390 cylinder.This is going back to the beginning, but I was curious why you picked a 661 piston for your p1 saw. Was that what you gleaned from the tube was what ironhorse was using or was it just something you had lying around. I have a hard time watching his video's.
The seal removal tool showed up today and it's a good thing they sent two replaceable tips (which I say 'because I broke one trying to get it under the seal lip.) So I filed down the side profile on the 2nd and was successfully able to sneak it around the seal edge & pop things out
You basically screw the body into the seal, then turn the t-handle (it should line up with the center hole on the crank) it should pull the seal out with ease.How, exactly, does that thing work?
These seal removal tools make it easy and fast.
I guess I’d have to see it work…You basically screw the body into the seal, then turn the t-handle (it should line up with the center hole on the crank) it should pull the seal out with ease.
Pretty sure there are videos on YT. Should be easy enough to find.I guess I’d have to see it work…
