upstateamish
- 4:50 PM
- Jul 13, 2021
- upstate new york
Based off the "86r" idea that i've seen on youtube and other links in this forum (e.g. https://opeforum.com/threads/372-385-390-hybrid-is-it-possible-been-done.17302/) Between that thread & the videos which have caught my eye I was curious if I had the skills to try and make it work.
For the moment there's no machinework on the bottom end to get things to fit.
The finest cheapest 365 clone saw I could find... it arrived with a hard nose bar, chain and bearing the name of "Hnsavrqua" looks legit
Addtional aftermarket parts:
- 55mm Husqvarna 390 cylinder with base trimmed & turned to fit the bottom end. Intake JB-welded to get timing correct (no base gasket)
- ms 661 piston
-- turned down 55mm bit of a pop up and and clearanced to fit the rod.
-- rings ground to fit the 55mm cylinder
- 390 intake boot (home made clamp, new one arrived not in place yet)
- 395 Carburetor with 372 X-torq choke lever on choke rod
- x-troq choke for 372/365
- x-troq lowtop air filter horn (hollowed out)
- x-troq top cover (to fit over the larger cylinder, had to trim a bit, also had to trim the chainbrake to clear the cover)
- Opened up the exhaust with an Echo CS-620P exhaust deflector
- OEM dogs from a full wrap kit I had left over from another project
Initial timing numbers landed (Top end isn't ported yet)
- Exhaust: 98.6
- Intake: 80.8
- Transfers: 122.2
Squish (with a base gasket)
- 0.025"
As arrived:
first glance, didn't look terrible for the sub-200 dollars shipped to my door (search for "24In Gas Chainsaws 65CC " on amazon, even cheaper off aliexpress...)
I didn't try to start it and just started tearing it down. Most parts looked ok, but a couple... well, they're not 'great' I would say quality of parts shipped reflects the price
Topend that shipped with it
Continued in the next post
- ms 661 piston
- Exhaust: 98.6
- Intake: 80.8
- Transfers: 122.2
- 0.025"
As arrived:
