Husqvarna 562 Repair Thread
Onan18
OPE Sponsor
3:44 AM
Georgia
It is really not worth putting bearings in an old bottom end, especially a five screw case, these updated short blocks are the way to go.
Start by placing the flex limiter.
Install the carb floor, leave the one screw for the ground wire out though.
Onan18
OPE Sponsor
3:44 AM
Georgia
Set the fuel tank in place.
Pull your lines and throttle cable through.
Install the screws into the mount, don't forget about the chain catcher on the PTO side.
Drop your oil pump and lines back in.
Wind in the worm gear and install the screws.
Onan18
OPE Sponsor
3:44 AM
Georgia
Notice how the case has a nice place for the wires to go so they don't get smashed.
Pull the wires through the case.
Route everything and lay the coil in place.
Push the coil as far to the front as you can and temporarily install the screws.
Fasten the ground down.
Onan18
OPE Sponsor
3:44 AM
Georgia
Grease the bearing and drop it on.
New rim is a good idea since the drum is off anyways.
Drum in place.
New clutch installed, old one the springs were shot and it had a fair amount of wear on the shoes and spider.
Install the bar pad plate.
Onan18
OPE Sponsor
3:44 AM
Georgia
Remember the mistake in assembly that I mentioned earlier, here it is. The small plastic guard goes over the bar plate not under it.
New air filter.
Installed.
Top cover and front handle on.
And together.
Onan18
OPE Sponsor
3:44 AM
Georgia
When I first fired this saw up it ran like crap, bad off idle hesitation, erratic running at high rpm, and absolutely refused to restart when warm. It came to me as a non runner so I didn't know it's history. I tried a reset but no luck, a new EL 48 fixed it right up however.
