Husqvarna 562 Repair Thread
Backtroller
1:10 AM
Land of Badgers
Totally agree with you. I’m taking about the hardware store, external hex bolts with the number”8” on them 1A168DD1-18D0-41AF-9CA5-227346FB1BC9.jpeg
Onan18
OPE Sponsor
2:10 AM
Georgia
This is what was on the saw when I got it, they are the correct length and thread pitch, and they have the serrated lock washers under them so they actually stay in place. Plus I am out of the correct bolts at the moment. :BangHead:
Derf
2:10 AM
Long Island NY
Yeah I did not think you would have put them on. Just funny since everyone complains about Husqvaranas having mismatched hardware.
The Stihl fan boys complain about Husqvarna having 4mm/5mm bolts instead of all one size, mismatched hardware, or missing hardware because it rattled loose.
But all the “stripped thread repair” posts are on Stihls it seems. Go figure.
tickbitintn
1:10 AM
middle tn
yeah and their calendars are all on January......
:stick:
Onan18
OPE Sponsor
2:10 AM
Georgia
Time to disconnect the throttle cable.
Mash the trigger.
Hold the throttle shaft open.
Release the trigger and the cable will.come out of the catch.
Pull it out of the way.
Keith Gandy
Maxima K2 40:1 87 Pump Gas
1:10 AM
Provencal, Louisiana
Onan18
OPE Sponsor
2:10 AM
Georgia
Pull the plug for the wiring harness out of its retainer on the carb.
And unhook it.
With everything out of the way the carb will come out.
Top barrel is for the fuel charge, bottom two are for the Stratos.
Onan18
OPE Sponsor
2:10 AM
Georgia
At this point the tank comes off.
Unplug the coil wire.
The coil and wiring harness lift out but are not free of the chassis just yet.
Remove the cylinder, four bolts.
20180103_144727.jpg And lift the jug off.
