nnero
- 3:14 AM
- Jan 24, 2016
- Delaware County, New York
The squish was .05 after removing the gasket. I didn't measure the gasket.
I thought you mentioned at the start of the thread you ordered a closed port top end kit ??It's a hyway closed port cylinder and windowed piston. I don't have a compression gauge at the moment, mine crapped out. Compression feels good which means nothing but you really gotta yank it without using the valve. I'm gonna plug the decomp hole and check everything over before I try again
So true. I have a Harbor Freight $15 gauge. One of my 55s ran great but showed 85 PSI. WTH??? Got a $50 Actron gauge - Same saw read 170 PSI. The HF gauge read exactly half of the Actron on 5 different saws. The HF gauge does work on 2 liter car engines.I think compression checking has quite a few variables and can be misleading in some ways but let us know how it runs for ya!!!
They are my default ring to use.. unless its OEM parts and even then Caber very often is what you get.I will measure it with new gauge. Wonder if a new caber ring would make a difference?
