chipper1
- 6:27 AM
- Jun 25, 2016
- Grand Rapids Mi
Wow that's loose buddy.These Hyway closed port top end kits have Very loose squish. I just mocked mine up without a gasket and got .055". That coupled with less than top notch piston rings could very well give you low compression.
Where is the thread that you had the video of the 55 you had done the work on. What's the thread title, and is it here or "there".
Thanks.
You should post that video here so they can see what one does with a bit of work.
I just need to do the cab and lines and my first closed port will be ready. The second will need the same as well as a brake, since I've made a third my parts saw.
