Husqvarna 394xp ... splitting a case without a splitter!
Mattyo
Youtube speciawist
5:39 AM
Farmington, CT
Everyone give me crap about my bench....ya ya ya.... I have my nice new bench in the shed which is a slab of wood wood 3" milled. just the shed isn't setup as well as my basement. I can stand in one spot and have everything I need depends on where I turn....one day my shop will move out of the basement and into the shed. for now....I'm stuck :(
Glad everyone likes the vid though
Keith Gandy
Maxima K2 40:1 87 Pump Gas
4:39 AM
Provencal, Louisiana
One other thing that will make it alil easier getting the bearings off is to tap a broad chisel in behind the bearing will give alil room behind the bearing for the puller to get a bite
5:39 AM
I've used the same 1" chisel for years to take bearing off the crank,it's got the perfect taper.
One of those tools a guy would be lost without. Hard to find an exact replacement
cus_deluxe
terms of service violator
5:39 AM
Michigan
Nahhh just havin a little fun. Besides, my bench only looks like i use it, i just sprinkle some tools and spare screws everywhere.
Mattyo
Youtube speciawist
5:39 AM
Farmington, CT
I've tried to remove bearings with heat..
Doesn't work 4 me . ..but maybe I'll give it another shot.
beaglebriar
The Peanut Gallery
5:39 AM
Warren Center, PA
A regular two jaw puller works well to pull the bearings off the crank. A little heat helps especially when there's a brass oil pump gear to pull off along with the bearing.
Great vid as usual Matty.
