Husqvarna 254XP Rebuild
ZukiRyder440
Breaker of recoils
10:04 PM
NY
The differences between the 262 and 254/257 are top end (bigger bore and taller cylinder), taller plastics (for the taller cylinder), muffler, air filter, carb, longer rod for the 262 and a few other smalls.
XP_Slinger
They’re Just Saws
10:04 PM
Central NY
I just did a little research that said the 254 had a 2 shoe clutch and the 262 was a 3 shoe.
Yup and I know from experience that a 2 shoe clutch will get smoked by a modded 262.
gee wiz info...clutch assembly from a 357/359 is a bolt on upgrade if you have the newer style oil pump drive.
XP_Slinger
They’re Just Saws
10:04 PM
Central NY
Gonna do some more clean up on the lowers. The are so long because my “OCD” kicked in when I was trying to make them perfectly straight at the bottom. I had an “O *s-word” moment and didn’t go any further.
Glad you stopped, those cylinders are NLA but you’re doing good work bub. Don’t forget how much my 254 impressed you with just a thinner base gasket, MM and a little timing advance.
ZukiRyder440
Breaker of recoils
10:04 PM
NY
Yeah I know. It makes me giggle every time I run it:)
