Husqvarna 2100 thread
Frank bierce
4:19 PM
Here's the tail end of Dad dropping the tree he wants his bar top for his cabin out of. This is the first tree he's cut with a 2100 in 20 years. I think he was pretty exited. I asked if he wanted to drop it and I hardly got the words out of my mouth and he was taking the saw out of my hands.
Nice!! :). I bet he enjoyed that!!
As soon as the tree hits...the real work begins. Lol.
flying pig
5:19 PM
Grande Prairie, Alberta
For sure, but we got it limbed and cleaned up pretty quick. We actually got pretty lucky and there was no traffic at all in the few hours we were there. Lucky as it had the road pretty well right blocked off. Lucky too as the tree didn't break and the big crotch in the middle survived to become his counter. Hopefully it works out, guess we'all see in a few weeks.
flying pig
5:19 PM
That's another pine tree. I will definitely post pics of the slabs in a few weeks when it is cut, so long as it mills out ok. The butt end has a vertical split 1/4 the way through, the top end has a split running horizontally 1/4 the way through both spars. Hoping it works out.
CoreyB
6:19 PM
South east iowa
I had a guy come into the shop today needing the front handle for his 2100cd. does anybody know where I could find one for him and how much it would cost?
Frank bierce
4:19 PM
Front handle?? Full wrap handle, or brake flag?
flying pig
5:19 PM
Anyone ever had a tank do this? I pulled the muffler off the mill saw to remove the inner dog and 7th mount and install a spacer where the 7th mount goes and found where my oil leak was coming from. Wondering if there is a bolt or anything that goes horizontally through the tank that would do this? I'll repair it somehow and run it as this saw is going to be run pretty hard on the mill.
NormalT
5:19 PM
Utah
I just found a box of flock air filters for this machine. What was retail on these, anyone know?
7:19 PM
Any filter for a 2100 is hard to find. I've never seen a flocked one only the nylon mesh type .
flying pig
5:19 PM
Put a new tank on the mill saw. It should be 100% now. It's a real good runner and a hard worker for sure.
Also pieced together the rest of Dad's 2100, replacing the rest of what was missing. Also I replaced the bad crank seals. Tried fitting the new canon 33" 404 bar, but the chain that was sent with it is 063 and two drive links short, it's 99 and I think I need 101. Also I want s full comp on it so I'm trying to find a Oregon 58L for it, then it's off to the races.
Daserlon
5:19 PM
Montana
Hey flying pig. Could you post some close up pics of your mill? I'd like to try milling even though i really dont need the boards. I've got a 2100 also. Awesome planks by the way.
flying pig
5:19 PM
It's a pretty simple design, but it's flawed as well. This was the first trip out with it and we will be making a few changes. Square upright legs are a PITA to square and retain. I wouldn't do them again. Next time they will be round and use a pinch collar to retain the mill platform and they will bolt through the bar rather than clamping on. Also it needs a second set of wheels above the first. These guys don't even contact the wood when you are in the bottom half of the tree.
bikemike
6:19 PM
Cottage grove mn
Here's the catcher I built.
Are you going to put a nylon sleeve over that. from my personal experience with long bars big chains is if it does derail and hits metal your back to sharpening a chian. if it's nylon chances are your not going to need to sharpen the chain . Put the chain back on and continue making your money
flying pig
5:19 PM
I'm not sure, it might get done but maybe not. It's made out of some pretty soft brass, it might be ok. Might build a teflon sleeve for it too. If the sleeve is too soft though it will end up in the steel underneath and that would be really bad for the chain. Ha ha.
flying pig
5:19 PM
Way to cold to do anything fun today up here in northern Alberta. -43 with the windchill today.
Thought I'd post a few pictures of Dad's saw all set up how he had it now. Half wrap, brake, double dogs, jungle muffler, a 33-36" bar (33" canon this time) and full comp 404 chain. Probably be Christmas before I get out to try it but it seems to run really well now and feels just like a new saw.
flying pig
5:19 PM
Cold enough the camera took foggy pictures even. Had to break out my bunny boots to go out and do anything today. Supposed to warm up to -20ish tomorrow. Might still savour some time inside though. Back to work at a mine this week sounds like.
