oaky
- 1:12 PM
- Nov 18, 2018
- massachusetts
howdy sirs
finished rebuilding a 385xp over mid winter but forgot about the carb issues when i put it away.
got the high and low at about 1 1/8 - 1 1/4 turns out currently.
but what happens is when i go to adjust the low speed screw nothing happens turning it rich, i can turn the screw all the way out and itll still hold the same tune. but it does die down when i lean it up.
also the idle speed screw will not hold steady when reving up, unscrews itself. looks like theres a little hole next to where the screw threads in, a piece of plastic is suppose to go in there maybe? to hold down the screw tight?
tried some plumbers tape on the threads of the screw that didnt work. tried fitting a spring in there, springs too big so it messes with the idle speed, chain whipping. so shes sitting on the porch instead of cutting soft maple today.
oh and i pulled the limiters out, if that makes a difference. maybe it seats differently when counting out from factory settings?
