- 6:25 AM
- Jan 24, 2018
- Extreme Southeast CA
Question at the end
Thanks
Thanks
Does it do it on a new drum/needle bearing?Question at the end
Thanks
yes, bearing. Cleaning and lubing it, or just dripping oil down into it frees it up.It's probably not the drum/bearing or shaft, but nice to rule it out.
Are the needles all there and in good shape/position? Metal looking worn on the edges of the cage itself?yes, bearing. Cleaning and lubing it, or just dripping oil down into it frees it up.
I wonder if Stihl makes a bearing that would fit the Husky. Fewer needles makes more sense to me to keep things cleaner.I think the answer is the closer fitting stihl washer and the plastic bearing cage acting like a seal.
I use a 3/8 air ratchet. It won't over torque it. My saw shop here I watch them do it one year and learned that, became my method too. .404 is my preference, if my saws were not mostly setup for 3/8 and the cost to switch over. I would exclusively run .404.. I always liked the external clutch.. Only downfall a timber faller.friend taught me, if it gets hung up on a tree it's a bugger to pull the powered. I told him I never had an issue, then a week later I git my 395 hung up, had to pull the powerhead and saw what he meant. I still think they are a great design and like you said disperse heat well.Question at the end
Thanks
That's wild. How many hours of cutting before this happens?
Not many at all. Couple big oaks with the 2188That's wild. How many hours of cutting before this happens?
