Husky internal clutches choke with dust…?
HumBurner
7:16 PM
Humboldt
yes, bearing. Cleaning and lubing it, or just dripping oil down into it frees it up.
Are the needles all there and in good shape/position? Metal looking worn on the edges of the cage itself?
timg
10:16 PM
Keystone State West
Dave, I'm not expert by any means. But I think a rim sprocket with radial ports on the one side would help out in your situation on the Jonsered. The sprocket side with open ports should face outward. It would use centrifugal force to throw out chips and dust and prevent packing material into the clutch drum bearing. Your powermate may have these oval ports. Can you turn your rim over to see? I would look at this first. If not get a Powermate with radial ports on one side and mount them outward. Hope this helps. Worth a try sir.
Woodwackr
8:16 PM
ID
I’ve cut a lot of Euch…back in Cali…both green and dry like your stuff. The older red gum is the worse. When green it cuts like butter…5yrs dry, not so much. The problem is the high oil content in the wood. It can seize up bar tips just like clutch bearings. I always wondered about carrying a CO2 tank to blow saws out when in the field to keep the dust down during a full day of cutting.
Good luck :p
Normzilla
7:16 PM
Cazadero CA
Question at the end
Thanks
I use a 3/8 air ratchet. It won't over torque it. My saw shop here I watch them do it one year and learned that, became my method too. .404 is my preference, if my saws were not mostly setup for 3/8 and the cost to switch over. I would exclusively run .404.. I always liked the external clutch.. Only downfall a timber faller.friend taught me, if it gets hung up on a tree it's a bugger to pull the powered. I told him I never had an issue, then a week later I git my 395 hung up, had to pull the powerhead and saw what he meant. I still think they are a great design and like you said disperse heat well.
qurotro
Cookie Cutter
9:16 PM
Ar
But I really hate the Stihl's very tight and thick washer. I've come across 2 that binded up with the clutch drum and the crank slot that fit the E clip would wear out eventually cause the crank E clip slot nolonger holding a E clip anymore.
