cus_deluxe
terms of service violator
- 1:28 PM
- Jan 3, 2016
- Michigan
do you know what caused the need for the new piston?
If you do go down the spark plug hole to feed in Vac/Pressure ...don't forget to make sure the piston is in such a place that the transfers are open to the top end .You will only go to .05 bar so a path straight to the crankcase is preferable. I maybe quoting the obvious to someone who knows...apologies if thats the case.By the way, how do you pressure test a 51 with that impulse thingy tube????
Glad you got it figured out. We've all had those homer simpson moments. Good job walking away and resetting.
STOP THE PRESSES! NEWS RELEASE! SAWS START BETTER WHEN THE FUEL LINE IS HOOKED TO THE CARBURETOR!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Well this is why we walk away and rest awhile, I looked at the saw this am and found that the fuel line was over the carb barb and not on it. I hooked up the line and it fired on the third pull and idled fine. Thanks for all the input and I will now adjourn to somewhere that I can kick my own ________________
