WANTED husky 51 CP, 45mm piston
9:44 PM
pa
Like it says, must be windowed.
Some dumass straight gassed this one.
Looks like been on weenie stick over fire too long.
Can take associated other parts if you got em.
Hoping for new.
Ronie
9:44 PM
NC
Hoping for new.
You can use a 353 piston if don't mind grinding on the lower transfers, I've got two like that.
5155
9:44 PM
pa
Think I found a piston, mail man pending.
Either these are rare or I'm a bad hunter or both.
Ronie
9:44 PM
NC
Where did you find one at, me and a lot of others have looked with no luck?
5155
9:44 PM
pa
Ronie
9:44 PM
NC
I was hoping you had found a source for new ones.
5155
9:44 PM
pa
I was hoping the Duke would produce some, coated or any.
Nope, I called there.
I've heard that 353 trick.
Saw some other pistons mentioned too but not tried any of them.
If a guy had access to a bunch he could sit and measure....
5155
9:44 PM
pa
For what it's worth.
Got the piston, it shipped from lil red barn.
45mm, CP, Model Jonsered 590 pop up.
It is the only one I found 45mm CP.
Wish me luck.
The casting,, if I knew a polisher guy..
