- 10:45 PM
- Dec 29, 2015
- Strong Island NY
So, theoretically, if one could grind the Venturi of the 120 out to 16.66, it could flow almost the same. Whether or not one would get enough speed increase to have the Venturi function is another question.120 vs 87
Venturi 15.08 vs 16.66 mm on Walbro home page....
Throttle plate 17.4 vs 19mm
If two carbs have different bores but the same Venturi diameter, does the larger bore carb still flow more if the Venturi is the bottle neck?
We all know poisselle's law of laminar flow, where the biggest limit to flow is the tube diameter as the denominator to the 4th power. The length of the tube is much less restictive.
