Huskvarna 350 fuel tank vent
94BULLITT
7:06 PM
VA
Is this were the tank vent should be?
94BULLITT
7:06 PM
VA
Thanks I'll check out the other side for the hole.
Sent from my SPH-L710 using Tapatalk
94BULLITT
7:06 PM
VA
Is this all there is supposed to be to the vent?
Onan18
OPE Sponsor
7:06 PM
Georgia
hard to tell from the picture but i think there should be another white disc in front of that.
Joe
94BULLITT
7:06 PM
VA
Here is what was in it.
Mattyo
Youtube speciawist
7:06 PM
Farmington, CT
Should be either an additional larger white disc...or a plastic unit that has discs in it.
They are not cheap. Hold it in by using a soldering iron to melt the two pieces together....a little bit. Don't need much...and don't do it with gas in the tank lol
94BULLITT
7:06 PM
VA
I also read something about using a MS660 tank vent. I need to dig that up.
94BULLITT
7:06 PM
VA
455 rancher uses the same white plastic vent... has a nipple on it.
http://www.ebay.com/itm/537359501-H...0-575-346XP-334-340-350-455-New-/130797074284
for reference
Thanks, for the link with the p/n. I think I have an early 350, I wonder if that little piece in my tank was all they did for a vent on them back then. I can't find that thread were someone said they used a 660 tank vent. I assume they used a vent like this. http://www.ebay.com/itm/10X-NEW-STI...343137?hash=item3ac06b0861:g:ULwAAOSw9uFW-hCf
Mattyo
Youtube speciawist
7:06 PM
Farmington, CT
On yours there was a larger disc as well. But you can use the nipple one instead
