How to use and read timing degree wheel?
Mattyo
Youtube speciawist
4:06 AM
Farmington, CT
i cut a weeeee bit too much off the chassis... I didn't have the piston available at the time, so I guessed... so thats only 15 thou popup
can't start the thing yet.... missing a starter switch.... DOH
idiotwithasaw
3:06 AM
Ky
Got my wheel in the mail today. Guess I've gotta decide which one I wanna check first.
Mattyo
Youtube speciawist
4:06 AM
Farmington, CT
well, it was either that or cut squishband....easiest for me to put it on the lathe and cut the popup in this case. ...its ONLY 15 thou.
Mattyo
Youtube speciawist
4:06 AM
Farmington, CT
Ben, that looks cute and expensive. after doing this, I like having a bigger wheel. ...but thats just me
idiotwithasaw
3:06 AM
Ky
It wasn't that bad, I considered making my own, but I'm not good a drawing let alone cutting circles. Plus I don't have a printer, and I figured it would take a good hour or more to make one that $14 from eBay and free shipping to my door didn't sound too bad.
Plus you should know by now it's not the size of the tool but how you use it. ;-)
Sent from my HTC One using Tapatalk
idiotwithasaw
3:06 AM
Ky
If the size of the tool is all that matters, some things may need to be re evaluated in your life. Lol
idiotwithasaw
3:06 AM
Ky
Ok guys, how wide is too wide on a port, go for the skirt, or a little more conservative.
And specifically on a transfer port how wide can I take one of those? For a quad and dual transfer.
4:06 AM
General rule is 65% of bore diameter, provided you stay a couple mm away from skirt edge. Transfer width can be opened toward intake, but be careful of ring ends
4:06 AM
I'm not the expert here (hopefully some one else will say something) but be careful with opening up the upper transfers. If you decrease velocity, you can decrease performance. Bigger is not always better. (I'm just repeating what more knowledgeable people have said).
ft. churchill
1:06 AM
Along the '49 trail in Nevada
When widening, be certain to leave 2mm from any edge of port to piston so that it seals and does not "freeport". One the intake side the same warning apply, do not open anything up such that the ring ends will open up into the ports or transfers while the piston is traveling up and down.
The 65% rule is for the same reasons, too wide of port will allow the rings to pooch out into the wide opening, and snag on the edge of the port with catastrophic failure. Generous chamfers around the port openings help as well to prevent this.
