Terry Syd
- 5:49 AM
- Jan 18, 2016
- Comboyne, NSW Australia
A weaker spring will 'ramp' in the fuel quicker. Likewise, if you re-drill the transition holes you can change the ramp. A larger hole closer to the throttle plate will ramp in the fuel quicker, putting the larger hole away from the throttle plate delays the ramp.
Those carburetor mods only affect throttle response, they don't affect the starting. I'd check the coil gap first to make sure I was getting the hottest spark for starting.
