How to square file
Wolverine
dilligaf
10:27 AM
@Wolverine
You used the term "hybrid chain" earlier
Is that square ground but with the gullet hogged out with a round file?
I use that term for a round chain that is being converted and the side plate isn't fully straight, still some round to it. I've tried it and I feel like you still don't have the full benefit, smoothness wise, of fully square. Not a fan... and I'm talking firewood chain here, not race.
3browns
6:27 AM
Fishhook, Alaska
So in a chain that started out square ground the side plate should stay square and if a chain is converted it should eventually lose the round side plate and end up square?
3browns
6:27 AM
Fishhook, Alaska
I am going to have to come up with a bench and a vise of some sorts when I get back to Hawaii so I can work on learning
Don't think I am going to master converting a chain or even simple square maintenance for that matter sitting on the tailgate of my Taco holding a saw between my legs
And momma said the granite countertops in the kitchen are out too
Selfish so and so...
Could have sworn a saw maintenance agreement was written into the wedding vows 41 years ago...
3browns
6:27 AM
Fishhook, Alaska
3browns
6:27 AM
Fishhook, Alaska
If your going to convert round to square, you might as well get the side plate too. It’s only 3 more swipes
Are the extra 3 swipes simply more swipes "in the corner" so to speak or are these separate and aimed at squaring up the sidewall?
Not sure if that makes sense
It's late and I am tired
3browns
6:27 AM
Fishhook, Alaska
Lol, I did.
I made it through the 60's only to lose it in my declining years...
iu
Wolverine
dilligaf
10:27 AM
The first 3-4 I use an older, less sharp file. This one takes the brunt of the job. Then i switch to another to get the toof where I want it. Then I use the Stihl file for 2 light passes to smooth the finish. Probably a nail retentive, but files ain’t cheap and I can get more mileage this way.
I had some experimental years when I was younger so I can sympathize.
:abduct:
