How to square file
2:57 AM
I’ve had some go dull in as little as 10 touch ups and some go for way more than that. How hard to push and how Rd you are on the corners will make a difference in how long they last. Wire brush to keep them clean will help life.
2:57 AM
When converting to round, I started flipping the file end for end and pulling it up through the corner for a few swipes on every tooth. And then a few more swipes from outside in. Once I had a path, the file didn’t dig into the corner as bad. I think catching the sharp corner shortens the life of the file
Carhartt
2:57 AM
Central Pa
I don't have the time to read all the responses. Has anyone tried the Stihl FG 2 with the Pferd triangular file to try to come up with angles? Please forgive me I am not a square sharpener and don't follow it. Is there any benefit in hardwoods? I have heard it is more of a soft wood tooth.
Deets066
AKA Deetsey
2:57 AM
Never tried the FG2, but properly sharpend square is more efficient than round in every way
Magic_Man
Oh Yea !
2:57 AM
SE Ohio
I tried it a few times with the grandberg jig which is very similar to the fg2, so it might work.
Battle Cross 2
2:57 AM
Southern PA
This^^^
With this...
iu
Its called a file card and using one religiously will greatly extend the life of your files
YMMV
20191212_090941.jpg Realized there's a file card hanging in front of my face where I file.
chipper1
2:57 AM
Grand Rapids Mi
I don't think its as easy as changing the file, but I'm sure someone could adapt one to do it.
As @Magic_Man said there was a grandberg jig guys were using, but you have t have the right one if I rememberer correctly as there were a few different ones.
Wolverine
dilligaf
2:57 AM
View attachment 212329 Realized there's a file card hanging in front of my face where I file.
I’ve become ocd with keeping the file clean. For a long time I used a stiff bristle tooth brush and cleaned it every 3-4 file swipes. Now I have a card but still clean them that frequently. To me the file cuts smoother and less chatter when free of metal. It also helps those expensive files last longer. I have 3 in rotation. The worse condition one is used for rakers and converting round, then the middle one does the loins share of filing, and the newest I use for one last pass for a smooth finish, not heavy pressure and if a chain is just getting a light touch up.
racerjohnbf
2:57 AM
VA
I don't know about the FG2, but I have used a Grandberg by installing a round collar on the 6 sided triangular file. My settings were 40° top angle and 25° tilt. The hardest part was setting file roll and to give correct side plate angle.
The older Granberg file n guide will hold a regular double bevel file. I have one but haven't tried it yet.
I'll second that! Smoother, faster, and holds and edge better IMO than round chisel.
Carhartt
2:57 AM
Central Pa
If I get some screw off time, ill try the FG2 with those settings. Can I modify a chisel tooth with the USG to make for easier filing. I guess just short stroke the wheel over the tooth and leave it more vertical.
2:57 AM
I use a lot of pressure, files don’t seem to last as long as they should. Even snapped a few after a little filing fluid
You and me both. I’ve had them only last one long chain converting it or bringing it back after hitting something. I see files like plastic wedges. If they break or get full buy more[emoji2371]
chipper1
2:57 AM
Grand Rapids Mi
Yeah I get it. It was for me too.
Go hoard some more, sell 3 cords of wood, put $20 per week in the safe, and in 6 months you’ll have it.
That's what I did, then there's the second machine, because they're like files, gotta have more than one just in case lol.
