You must've just done the dishes....This was a 3/8 round file conversion chain. I am doing better, but still a long way to go. Chain was basically rocked by previous owner.
Here is how it cut.
I'll have to keep looking. I hate buying tools marketed for something specific when there is usually an industrial version that lasts twice as long for half the price. So the angle between the two cutting surfaces should have a minimal radius is what you mean when you say square right? Because the double bevel, triangle, and 6 side don't have 90deg corners between the side of the file that cuts the top plate and the side plate.
I'll have to wait till I either get a non cracked 372 crank case from huztl or a splined clutch drum for the China saw to do a 3/8th chain
There is no radius to a square cornerI'll have to keep looking. I hate buying tools marketed for something specific when there is usually an industrial version that lasts twice as long for half the price. So the angle between the two cutting surfaces should have a minimal radius is what you mean when you say square right? Because the double bevel, triangle, and 6 side don't have 90deg corners between the side of the file that cuts the top plate and the side plate.
It’s not 90 degrees but it needs to have sides <=>
Full chisel has an outside square cornerSo no safe edges, blunt not tapered (or at least never use the tapered section to file with), and minimal radius. Cause there's got to be a radius on the outside edge of a cutting tool or there will be as soon as you take a cut with it.
I like that forward lean. It should feed real good.3/8” LP. Stihl 63PS. Just a fuzz low.
View attachment 127704 View attachment 127705 View attachment 127706 View attachment 127707
What kind of chain is that? I’ve been using Carlton K1L for .325.View attachment 127700
.325 isn’t that tough. I use a double bevel
Looks like you need to do some dishes.There is no radius to a square corner
View attachment 127689 View attachment 127690 View attachment 127691 View attachment 127692 View attachment 127693
Thanks. Hopefully my little 40cc saws will have the stones to pull it. Lol.I like that forward lean. It should feed real good.
Lol hopefully the rakers are tall.Thanks. Hopefully my little 40cc saws will have the stones to pull it. Lol.
At least one. Like a cereal bowl er sumfinLooks like you need to do some dishes.
