How to square file
Wolverine
dilligaf
2:27 AM
After seeing the 2nd pic it doesn't look as aggressive. Raker does look a little low but hard to tell by eye
Second pic shows a tad of beak, not what I'd want in a work loop but I do agree with your statement. It looks like a different cutter than the original.
Moparmyway
Its just a saw
2:27 AM
In a meeting
First one is a RH cutter, next two are LH cutters
Pictured LH cutters are probably a slightly different profile than the pictured RH cutter
But I agree 100% with @Redfin ............ that first picture will yield an agressive cutter with a taller raker due to the fwd lean that I believe I see and the inside top plate angle thats shown
Jimmy in NC
2:27 AM
North Carolina
Do you guys usually set rakers a little lower with a square file vs. a round filed chain? Or about the same?
Generally higher. If you have a dry hard piece of oak you have to drop them a little...I find it won't feed with them up high.
Those are around .025"-.028" and the chain that far back... that would be high. Set with a Husky progressive gauge on the HARD setting.
Sent from my SM-G955U using Tapatalk
Jimmy in NC
2:27 AM
North Carolina
Ran it around again and took the beak off. I have yet to install my new slide kit. It's got some slop in the old girl yet.
Jimmy in NC
2:27 AM
North Carolina
As for the top plate...I've struggled to get that to swing around on this grinder. Hope the new slide kit I can get to the top to swing around more around 15° or so. Honestly those angles hold up pretty good and even when I've hit fence wire it doesn't go all apart.
Hedgerow
1:27 AM
I like that top plate angle..
Looks fine to me..
Stihlbro
2:27 AM
Virginia
Good post. As long as it works for you, that is what is important.
