PA Dan
FYD
- 7:11 PM
- Dec 28, 2015
- White Oak PA
Yep this is how I square file...Mr fancy pants grinder
Ahhh... I see now. Thanks!
What do you guys do to get em that smooth?You’re not going to get grinder like smoothness when you just started. That takes practice so don’t beat yourself up on perfection. If it cuts good, time will hone your new found skill.
Good point. Im gonna keep tweakin until I get all of the angles correct.Don't need more chains ... just use em and repeat and you will know when it is better!
All just a matter of perspective I guess. LolDid your hands get dirty from the chain? Or did the chain get dirty from your hands? Lol
It will take some practice...then muscle memory. Are you doing it on the bar, or do you have a chain clamp? A clamp makes it much easier!! The deflection of the tooth while sharpening in the bar can make consistent angles tough as well. If sharpening on a bar, I usually try to get the chain pretty tight on the saw, which helps lessen tooth deflection.Good point. Im gonna keep tweakin until I get all of the angles correct.
View attachment 277127 Using the one on top.
