Hedgerow
- 7:06 PM
- Dec 29, 2015
- SW MO
But....325 also.
I’m still using up the 18” .058 loops I got on hand..But...
But...
I like 325 on a 346 for work
I got the side plate set real broad from the last project..Wow. [emoji106]
That explains the grind very deep and low on the cutter.
.325 is the most difficult one for me too Jeff. Oregon is a piece of cake compared to Carlton K1L, though. There is so much extra material to remove until I can get the file up in the corner. Takes forever, and is hard on files. Once converted, though, it’s straight forward after that.I tried to square file a .325 chain. Lol
I am too embarrassed to show it.
Glad to see Im not the only cheap basturd to grind off the safety bump on free chains.Indeed...
This is a 3 cube work chain on tank #2.
Still going..
Prolly get another tank out of it. 75% hedge, the rest is hackberry.
You should see what I did with the 2 loops of Vanguard I was given..Glad to see Im not the only cheap basturd to grind off the safety bump on free chains.
Man... That don't even look like a rock..
T-post?
You must of missed what I did with a vanguard on your grinder and 123cc at your place this year.You should see what I did with the 2 loops of Vanguard I was given..
I just try to get some value out of the stuff. The old "waste not, want not" saying keeps rolling through my mind, though it may be counter productive at times.
