- 2:52 PM
- Dec 30, 2015
- Brewster, NY
Thanks for the info Randy, but sorry to hear you re-injured. Take care of yourself.
But it's fun.
me too.. once again awesome timing randy.. thanksIm in....Have 1 that comes in for a service .
explain you're definition of "fun".But it's fun.
Once the oil pump override cable is loose you can get the oil pump out far enough to get the new hose on the pump. I heat the end of the oil a little and use the modded pliers to push it on as far as possible. Then you push the hose thru from the inside out toward the bar pad. This all sounds pretty easy, but that hose is stiff as hell. The pliers are a life saver.
Here it is installed, and ready to reassemble. No kinks, or buggers. Without those modified pliers, this is damn near impossible.
