How To Fix The MS661 Bog
VinceGU05
one day when i grow up...
3:50 AM
S.E Australia
I remember a big screwed up thread over on AS about a guy that had a MS661 that was bogging.
Here's the fix.......
Old coil.
Take that off and install this new coil.
Yes.......it's that simple.
If you have a decent dealer it won't cost you a penny.......
i bought a new saw here is Australia yesterday and it came with that coil .:dancing:
CR500
3:50 AM
Western NY
So basically if I contact the warranty system through Stihl I can receive the updated coil?
CR500
3:50 AM
Western NY
I am a Stihl tech at my shop, was just wondering if I need to fraud the system, or really just need go explain and cause a pain so they cover it,
No labor needed just want the coil
Redfin
Meh...
3:50 AM
Central Pa
Just went through this with my dealer. I had no issue with the saw after porting until I gave it a real healthy timing bump and a Maxflo.
He asked me what he should write is the issue. I told him it was lean coming out of a long cut. I told him about the fuel curves between the 4700 and 4701.
Edit: He asked me how I knew this cause he wasnt even aware.:)
Gearshifter
7:50 PM
New Zealand
If it is running well.......I wouldn't worry.
Here's what I've noticed on the ones that need more fuel. You will come off of a big cut and the saw will hurt around for idle and sound "off"......
Hey I know this is a really old thread but mine does this .. it runs good , idles good just a lean bog after a big cut , a couple of wee blips and it's back to normal.
This is a v3 mtronic , havnt done a recalibration yet as it still seams to runs really good
Is it anything to worry about ?
2:50 AM
How many hours are on it?
Gearshifter
7:50 PM
New Zealand
No telling. Bad wiring, bad trigger unit on the carb, needs a carb kit, small vacuum leak.....
I put a carb kit in same time as the module. I did notice the spark plug boot wasn't fully seated , slightly out from vibration I guess.
I'll have a look at the wiring when I get some more time.
Thanks for the tips tho!
